Terragen 3
Website:Terragen 3
Planetside Software’s Terragen 2 is a highly realistic landscape generator used to create background images in films and games such as Star Trek: Nemesis, Stealth and The Imaginarium of Dr. Parnassus. Our script renders a single frame of a snowy mountain scene at 640 x 480 on all the available CPU execution units.
        Intel Core i7-5930K
        Cyberpower Infinity X55 Pro GT
        Overclockers UK Infin8 Nebula
        Intel Core i7-4790K (4GHz/4.8GHz)
        Utopia Pandora
        PC Specialist Apollo 703
        Intel Core i5-4690K (3.5GHz/4.8GHz)
        AMD FX-8350 (4GHz)
          200
          300
          400
          500
          600
          700
          800
    Seconds, lower is better
Cinebench R15 64-bit
Website: www.maxon.net
Cinebench uses Maxon's Cinema 4D engine to render a photo-realistic scene of some shiny balls and weird things (we miss the motorbike). The scene is highly complex, with reflections, ambient occlusion and procedural shaders so it gives a CPU a tough workout.
As Cinema 4D is a real-world application - used on films such as Spider-Man and Star Wars - Cinebench can be viewed as a real-world benchmark.
        Intel Core i7-5930K (3.5GHz/4.55GHz)
        Utopia Pandora
        AMD FX-8350 (4GHz)
        Intel Core i5-4690K (4GHz/4.8GHz)
          500
          750
          1000
          1250
          1500
    Score, higher is better
Power Consumption
For the power consumption tests, we  measure via a power meter at the wall, so the numbers below are of total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to acheive. We use Prime95's smallFFT test to put the CPU under 100 percent load, while idle power results were taken with the PC sitting at a Windows Aero-enabled desktop.
        Utopia Pandora
        Cyberpower Achilles Pro 4K (4790K + GTX 780)
          200
          300
          400
          500
          600
    Watts, lower is better
